1 - 2 of 2 Posts
Which motor was in your stainz? there are 3 different versions (not including Growler) of the LGB short shaft motor, and only one version is now available which has no easily removable brushes. Both older stainz motors had the red and black modules. difference in these was one had no thrust bearings and the motor block has a single ball bearing at the end of the shafts. Other had thrust bearings and the bearings were not needed.
1 - 2 of 2 Posts
