Picked this up for $17 "30 LED" Work Light by "HUSKY"
at a local "Home Depot" about a week ago...
Here's the rear view, out of the package; note the flush ON/OFF pushbutton on the back.../DesktopModules/NTForums/themes/mls/emoticons/blush.gif
There's also a hanging hook mounted via a ball & socket joint /DesktopModules/NTForums/themes/mls/emoticons/satisfied.gif that folds flush with the back when not in use, & can be rotated 360 degrees when extended...
Did I mention - this thing is BRIGHT!!!!
It's also supposed to be water & oil resistant
, & uses a LiPo battery for a claimed 5-HOUR /DesktopModules/NTForums/themes/mls/emoticons/w00t.gif run-time per charge! It actually has 31 LED's - the 31st being a battery charge indicator (turns red when plugged into the included "wall-wart" charger at low charge, LED turns green when battery is 80% charged). VERY BRIGHT for outdoor night work (which I do a lot of!/DesktopModules/NTForums/themes/mls/emoticons/wow.gif ). I think this tool is rapidly going to get into the category of "how did I ever get along without this"/DesktopModules/NTForums/themes/mls/emoticons/blush.gif!
Tom
