1 - 3 of 3 Posts
Trying to connect a Lenz LS150 switch decoder to LGB switches. The LGB switches have 2 wire connections and the decoder is asking fo 3 wires. Am I trying to do something that can't be done?
Bob, in Arizona
Bob-
Have you tried using the instructions for "motorized switch machines" listed on page #7 of the manual? You will need to install two diodes and adjust the pulse duration for the outputs. Running with a 16VAC input, I'd start with a pulse duration of about 0.3sec. Only increase the pulse duration if the EPL drive fails to throw.
http://www.lenz.com/manuals/accessorydecoders/LS150.pdf
Best regards,
Bob
1 - 3 of 3 Posts
