1 - 20 of 29 Posts
I've been doing a lot with LEDs lately, and while I'm nowhere near the ability of so many people here I thiught this might be useful for some people
I bought a string of "warm white" Christmas lights, seventy bulbs. The bulbs are different from the usual LED dome--they are flat on the top edge but sort of come to a funnel in the middle. See the picture. The result is they seem to cast a great deal more light to the sides. They don't have that painful squint effect when you look at them end-on
The color is good, much less blue than the typical white LED, but I've had good luck painting them--I've been brushing on some tamiya clear yellow, as George Schreyer recommended, and the result is much more like an incandescent
The interior lighting is three of these Christmas light painted yellow
In this pic the building in the lower right corner is lit with three of the Christmas LEds dipped in Tamiya clear yellow
The "fire" in front of it is red, orange and yellow leds. The three building in the left foreground, and the station, are lit with amber 4 watt malibu lights
This combine has two Chirstmas Leds in the passenger section, both bubs painted with floquil reading yellow. It's very hard to tell them from incandescents
Click for photo
[/b]
[/b]
I found them at one store I went into srt of randomly, and now I wished I'd bought more. The shape of the bulb really seems to make a difference
The downside of these is I can't get them out to the plastic holder--they're molded in. So they'd be tough to use as headlight, for example
Great pics!
I bought a set of 30 warm white LEDs for future modeling use. They look similar to yours.
How can you tell what voltage to use on the individual LED?
I also bought a couple sets with colored "bulbs" for home use. I was surprised that none of these sets appears to have a transformer.
How can they use straight 110v house current?
Thanks Ray! It took me forever to get decent night shots. They key was a tripod and shooting steadily from dusk til close to darkness. Shots taken when it doesn't look dark to the eye look dark in the picture
The lights I got had three big molded plastic cylinders inline, I assume they had diodes and /or resistors to step the voltage down. I could not get one open to find out
Posted By Ray Dunakin on 01/15/2009 7:25 PM
Great pics!
The LEDs are probably in series, so divide the listed working voltage (110V or 120V) by the number of lights in the string and you have the working voltage for each LED.
110V/30LEDs= 3.667V per LED
LED's are not voltage devices!!!!
They have a suggested voltage for maximum use, but are really current devices with a max voltage rating.
It is very important to watch the current on LED's.
I use a meter and set my led's to a 15 ma max current at 22 volts. (I have 24 volt supply to a TE which gives 22 volts max to the track.
Some just tie led's direct to batteries and they work. This can be dangerous as the current is not being limited and may be well over the 15ma which causes excessive current draw on the battery and the led can get hot and burn.
Discussion Starter · #12 ·
True! A good reminder
I have used this led calculator a lot: http://led.linear1.org/led.wiz
The problem is that you don't really know what the forward current rating is for a bunch of Chrstmas light leds. I've been using the figures for Radio Shacks 5 mm white leds. But it's guesswork. I have sometimes just sat with bunch of resistors and tried different ones till I go the brightness I wanted
All the WHITE LEDs I have purchased to date have shown a 3.6 voltage drop and have a maximum current rating of 20 milliamps.
The Ngineering web site has the best tutorial on LED CIRCUITS I have ever found. They also have the CALCULATORS for determining the proper resistors required in a circuit. I have added both to my browser’s FAVORITES.
All Electronics currently have a 24 LED, 24" LIGHT STRIP, catalog # LBR-24P. It operates on 24 volts DC at 80 milliamps. Twenty-four, 5 mm, bright white LEDs are staggered in two rows with built-in resistors mounted on pc board. There are holes at both ends of strip for soldering connectors or wire leads.
The LEDs on the board are in groups of 6, so the board could be cut to provide lighting circuits of 6, 12 or 18 LEDs.
Although I use resistors in my LED circuits to limit the current to less than 20 milliamps, you can use a couple of AA cells to test a white LED. As long as the AA cells have a total voltage of no more than 3 volts, the maximum current to the LED will not exceed 20 milliamps.
Adding the female connector from an All Electronics two-pin plug set (catalog # CON-240) to a twin, AA battery holder makes a cheap and easy tester for white LEDs. The battery holder with switch is available from Radio Shack and most electronic shops. The leads of the LED simply slip into the connector for testing.
Yep, but test a red or green led and you instantly convert a LED to a DED!
It's good to know the voltage drop when calculating the resistor, BUT, the point people are making is that CURRENT is the key. The current through a led can vary dramatically by a change of just a few hundredths of a volt.
Coming back with a shortcut that usually works is not helping people "stay out of trouble" .... again my example, you take your tester to a red led and it burns it out.
Finally, you will see that manufactures will specify the maximum current, but will only specify the NOMINAL forward voltage, again underscoring the importance of controlling the current no matter what the voltage.
Let's give people the best advice, that is most bulletproof. I have hundreds of shortcuts I use myself, but would never advise beginners to use.
In the spirit of helping others the best way,
I used to have a spec sheet for a "DEAD" (Darkness Emitting Arsenic Diode). It showed that this device was very useful to not illuminate Top Secret displays and controls. I don't remember what company put the spec sheet out, but I also remember a Signetics spec sheet for a WOM (Write Only Memory).
Apparently, an Engineer at Signetics was frustrated with the seemingly useless multiple approvals required for a component specification, especially because it appeared that no one actually checked them, they just hung on to them for a while and then signed them. So he created a specification for a "WOM" (Write-Only-Memory) and sent it along with other specifications to be approved. Signetics management didn't learn that it actually got published in a new catalog until customers began asking for "price and availability" quotes. Signetics re-published a corrected edition of the catalog and asked for the "erroneous" ones to be returned... which some people did and others didn't . Then, I think in 1974, Signetics did a large advertisement in "Electronics" magazine's April issue as an April Fools' joke. The spec sheet included what initially appeard to be conventional charts about the device, but were things like: "Bit capacity vs. Temp.", "Iff vs. Vff", "AQL vs. Selling Price" and my personal favourite "Number of Pins Remaining vs. Number of Socket Insertions". It listed the device, the 25120, as requiring a 6.3 VAC VFF supply, a +10V VCC, and VDD of 0V, +/- 2%. It was suggested to be useful for recording the last data of the flight path of munitions and bombs or for Top Secret data that no one was ever allowed to see.
I think the DEAD came out of this advertising sillyness along with another device, but I can't remember what the other device was. But I do remember Engineers sitting around discussing whether one could actually create a DEAD.
The other device was an op amp, with very funny specs.... like the rise time was "about 8:30 am", speed was in "furlongs/fortnight", and other silliness... I will look for the spec sheet, came out in 75-78 I believe, and it was from a company called "Nominal Semidestructor"...
Posted By Greg Elmassian on 01/16/2009 3:03 PM
Somehow I don't get the feeling that your post was written "in the spirit of helping others the best way."
In the entire post there was never anything mentioned but white LEDs. If you really wanted to help you could have just said that the tester might not be suitable for coloured LEDs, instead of bashing another person's post.
Jeeze... it's not bashing.... it's a suggestion... supported by facts that are indisputable and also based on many years of experience, and also coincide with the advice of others. Why do you have to up the ante?
Do you think that all beginners or everyone realizes that red and green have different forward voltages?
I'm suggesting caution, and you call it bashing... so bashing is when someone does not agree? I presented reasons, facts, experience...
I know, you are right... no one could possibly make that mistake, everyone knows that red and green leds are different and not to use your uncontrolled "Tester" on red or green leds...
Come on Paul... think of all the people reading this... pretend you are trying to help all of them, who might read this thread a year from now, and not make it a "trick" that only works with white leds....
The best advice is the advice most helpful for all... and I am sticking to my opinion...
1 - 20 of 29 Posts
