Well guys, I decided to go with Kadees as they look really good and have a great reputation. My first conversion was my USA Trains GP9. This conversion was extremely easy and left me with a positive feeling about my Kadee decision. Once I started my SD70MAC, things changed. I tried 2 different knuckles both of which were recommended on the Kadee site and neither one simply 'did the job'. They both require reconstruction on the engine and some extra work that leaves the engine looking somewhat Jimmy-rigged. I decided to start my SD40-2 so that I could ignore the headache of the SD70MAC for a while. Things went from bad to worse when I spent several hours trying to get this one right. I had to file the heck out of the pedestal, gear box, and a few other things just to get it to sit right on the pedestal. I followed the instructions on the site and contrary to the instructions (which are not the easiest to understand anyways) more filing was needed than they stated.
At this point I am wondering if Kadees are really worth the trouble when the USA knuckles do the job right out of the box and do not require grinding, sawing, tapping, cutting, filing, sanding, whatever... plus they look good enough. If they made specific couplers designed for each locomotive it would be very nice, unfortunately it is more like a one-size-fits-all-provided-you-grind-the-heck-out-of-your-locomotive! So Kadee, how about working with us a little here? What do you guys think of going USA Trains vs. Kadee? Are Kadees worth the trouble in the long run? Thanks.
-Will
-Will
