Guest
·Posted By Dan Pierce on 11/10/2008 4:28 AM
While I and others consider Kadee's to be the best, they do have one small issue.
If not body mounted, they will come apart on uneven track due to the trucks making the coupler flex up and down.
If body mounted, this just can not happen.
Unfortunately on some engines this will require hacking of the body to get the coupler mounted properly.
This is true, if the truck mounted couplers are not properly mounted, then the coupler tang can move upwards or downwards under load and the couplers will slip under/over each other. This particular problem is worse with the #1 Kadee couplers. However, most truck mounting configurations can be easily constrained such that the coupler is fixed in height similarly to a body mount and then this problem does not occur. The solution is different on every kind of car and loco but it can and should be done.
Body mounts just do not work in some track geometry situations. The obvious solution is to fix the trackwork, but in some cases this is not practical. Truck mounts can be made to work and are more tolerant to some particular track geometries.
