All good comments, and Chuck brought out a unique advantage with the prototypical slack, although this is only in the 830/820. Stick with the G scale versions if you have more abrupt vertical transitions. And, no, the Aristo coupler has not improved, recently virtually all GP-40's have been shown to have defective couplers, i.e. pull apart under load, 24-30 cars. With Aristo's change to a new factory, it seems there are more problems than before. (Funny though, USAT stuff has not suffered the same way, even though both are made in the same factory AFAIK by Sanda Kan).
If you want to run long trains, get Kadees now. At under $6 a car, and cars about $60, you are only adding 10% cost to your rolling stock. If you do it as you go, it won't hurt much.
