I'm not sure this is the right forum section to post this question but here goes.
I've been working on a caboose repaint project and while I'm at it the couplers and trucks are getting a cleaning. These all use Kadee couplers (G scale) and have been on for a few years. But in the cleaning/rehabilitation work, I've noticed that many of the coupler heads do not swing freely. When they don't swing freely, they don't always line up straight for easy coupling.
These Kadees (#831) are all truck mounted (talgo) since I like the ability to run my trains on anyone's layout even if they have tight curves.
I opened up the coupler boxes and found some dirt and crud in there. After a thorough cleaning they swing slightly better, but still not as well as brand new Kadees. I think the springs get compressed over time and don't have the force to spring back to center as well as brand new Kadees. So maybe this is why even after cleaning, the couplers some still don't swing well.
Now on to the question.
Do others here experience Kadees not swinging freely? What do you do to keep G scale Kadees working as intended?
I have Greas-em for our HO layout, but doubt this would work with such large couplers. And any form of lubricant, like Vasoline, will increase the crud/dirt build up in the coupler box. So is the only solution to periodically take them off for a cleaning?
What about changing out the old springs with new ones? Kadee sells them (#861), but changing these a lot could get pricey. I've tried pulling/stretching the old springs to get rid of the compression but this doesn't always help the couplers swing like new.
