After running the K28 with the new ports and pipework, I figured its about time to put the changes to use and complete the valve gear with working combination levers and a new union link and correct valve with lap.
I had made the necessary measurements on the combo lever for the center to center points and also aquired the steel to make the new parts. I had picked up some tool steel in .062" x .125" along with .062" and .078" round for pins.
All the pivot points were drilled and reamed to spec for a moving or press fit. The upper pins I used the .078 as the rarius rod was threaded M2 for the orignal connection. That was drilled and reamed to be a pressfit. The union link was fabricated by silversoldering on two tabs that end up being the yoke of the link. It connects to the OEM point on the crosshead.
Orignally I had connected up the valve gear as built from Accucraft but later found out that the valve rod and the radius rod need to be swapped on the combo lever as the valve events were set for a cross ported cylinder. I did not do any cross porting as I did not mind the radius rod in the opposite position from the 1:1 version.
Once all that was completed I had air tested again and it runs like a champ on ait down to below 5 PSI.
I also had removed the OEM Oring setup on the piston and replaced it with a dual split ring setup made of Tetron C ( It is a graphite impregnated PTFE, also very solid and heavy) That gave me a very good seal and great compression.
Since I rerouted the steam under the boiler to get rid of my burner woes I had lost the superheater, so I had habricated one from some 1/8" stainless tubing from Mcmaster-Carr. Bent with a mandrel bender and produced a very clean bent product. Once the fittings were soldered on I had wrapped part of it along with the complete underside pipe with a scotch 66 fiberglass insulation tape. It is rated to 450 degrees hopefully it will make a difference. If not the 2 flue superheater will heat it back up and dry it out. The superheater extends about 5" into the flue about 4" from the end of the burner.
I had also a few months ago added a rockguard to the pilot. It shows up in many books and photos on the K's and though it would make it stand out a bit from the crowd.
There is also a photo of the OEM ports on the cylinders, notice that the valve was not even riding fully on the face. I had lapped the cylinder, valve and steamchest on a lapping plate all the way to 3000 grit. What a great find that plate was. I found a 14x16 lapping plate 2 faced one smooth one .500 checkered. Found it in the garbage along with a bunch of other tools that were being thrown away in front of someones house. What drew me to it was the wooden toolmakers box sitting next to a pile of milk crates and boxes. Most of the stuff was rusted to **** but this along with a small crate full of tooling was not. The chest of course had seen much batter days and was left.
So next up is a new valve rod guide/yoke as the OEM one is too long and also does not guide the rod in any way. There is way too much deflection and I kept wearing out the valve rod oring as thats the only thing that centeres the rod in any way. I am also going to extend the valve rod with a new one that will also have a guide in the front of the chest.
Now for some photos....
