Wow - this editor has serious issues - The title of this page was about issues with quoting.../DesktopModules/NTForums/themes/mls/emoticons/w00t.gif
The WYSIWYG editor provided with this forum has a few glitches - here is one apparently:
When you select the "quote" function in a previously written response, the editor opens up the quote with the {quote} (its not visible) but does not add the closing {/quote} to close off the quote properly (Use square brackets - I'm using curly brackets, otherwise the editor will "interpret" my example). Then, when you write your response, your response gets included in the quote. The solution is to type in {/quote} (using square brackets) before your response in order to close the quote. Then your response will appear as a separate piece of text below the quote. (at least that is what is happening in Firefox)
