1 - 12 of 12 Posts
Hello I have quite a few LGB trains and they used to run on an inter-rail modular track system that was installed for me around my pool patio in Florida. I took it down 10 years ago and I have it stored in a warehouse in Michigan I want to reinstall it from the ceiling in my boat house and start using my trains again the company inter-rail went out of business and I cannot find any information on how to install the track. I paid a fellow in Florida who is no longer around to install the system for me in Florida I took it down I have no idea how you transfer it from the floor to the ceiling to drill the holes for the hangers other than a plumbob which would not be that accurate. I'm hoping someone on here has seen or installed one of the systems I can't wait to get it back in operation again. I'm adding a picture of the track System setting in my warehouse and a picture from the Internet of one that's up and running that was for sale.
Thanks
Hopeful
Wood Gas Shelving Metal Carpet
Building Wood Architecture Interior design Amber
To state right up front - I know nothing about this system other than what I see on line, but for one, to mount this from the ceiling, one would at least need the J-Hangers or something equivalent and maybe a cross support - see picture.
You may also contact this hobby shop that still shows some parts of that system on line to see if they can send you (or scan) an instruction sheet that came with the kits
Sorry - forgot that this forum doesn't allow tiff images.
Here is the J-Hanger:
Hood Automotive lighting Motor vehicle Automotive design Vehicle door
Mark,
Welcome to MLS.
I have never really understood to value to have trains running around at ceiling height as you really can't see them and enjoy them, but if that's what you want!
When you say 'boat house', is it actually on the water with water inside?
I would perhaps be concerned about dampness effecting the trains and tracks.
Have fun,
David Leech, Delta, Canada
What KRS shows is a single track and what you have is dual track. Bit of a balancing act and you HAVE to install both tracks.
Good news is that you only need threaded rod to hang it.
Finding the holes could be done with a laser. But a plumb bob works fine unless you have an 18ft high ceiling and you leave the structure on the floor.
If you have any heavy rolling stock I would go with a little more frame than single point suspension. A dive above 2 or 3 feet kills a model quite permanently
I have no direct experience of this system but I believe any competent handyman could install it in a ceiling environment.
Threaded rods are available at your local Hardware store, along with anchors or similar threaded devices that would be screwed in to the ceiling joists.
The issues are:
- it must be flat and level; but the threaded rods allow for adjustment.
- the rods must be secure and support the weight of the track and the heaviest train you have.
- you may not have ceiling joists where they are needed. I personally would not bolt the rod in to the sheetrock ceiling. You may have to take down the drywall to add crosspieces.
On the other hand, if this really is a boathouse, their may be an open ceiling so a good woodworker/handyman could easily hang it for you.
You'll also need some long bolts to fasten the sections together. I note on your photo the bolts that presumably attached it on your patio.
I do have a friend with a powder-coated metal track frame similar to yours. It rusted in his SW Florida back yard.
I have the assembly instructions that I can email you. I have some of the sets that I never used if you need to add on….
John
Could you email me the instructions as well and I will add them to the gbdb database.
krs9 (at) mail (dot) com
Knute
I just looked. I have a starter set….5 foot diameter 2 tracks and a 6 foot add on set.. This would add up to a 5 foot by 8 foot loop. I also have a 5 foot single track extension set.
If you emailme the pdf, I can create a link for the pdf and post that in the forum
To post the pdf in the forum, did you try using the paperclip symbol? That seems to allow pdf attachments - or change the pdf to a jpg and then attach it as an image.
1 - 12 of 12 Posts
