Posted By redbeard on 12/11/2008 7:23 AM
Hi everybody!
Caught this thread today and have a question. I understand the principle of cutting through every other one of the spokes and replacing the metal with epoxy, then doing the remaining spokes. BUT the Ruby drivers that I have only have spokes on one side. Would you still try to do this with these drivers? And if so, how would you proceed? The large "counterweight" area will be a pretty long cut to keep straight. (or curved in this case!) As a person who uses such a saw every day, I am not sure I would do this cut. Here is a picture of one of my unused Ruby drivers. Keep in mind that unless you remove the drivers from the axles, one set will have eccentrics to get in the way of the saw as well.
Maybe I am missing something here?
redbeard AKA Larry Newman SA #1956
Oops. Maybe I should have looked at my FWRR/Ruby first... Sorry - it's upstairs under the Xmas tree adding red and green train to the festivity.
My guess is that the only way to deal with this wheel is to put it in a lathe and cut through the outer part of the wheel/inner part of tread, to separate the tread from the wheel. Then epoxy it back. As I don't have a lathe, this is purely hypothetical and probably impossible.
