I'm beginning to lust after the Bachmann K-27 but have several concerns that you pioneering owners might be able to help me with. I am in a small town in the mountains of Colo and do not even have access to a hobby shop to look at one. From reading the threads, it appears that Bachmann has now solved most if not all the serious design issues. 1) Am I correct on this?
Unfortunately, I have several curves on my layout where I had to use 8' diameter track. 2) Will the K-27 easily take 8' diameter without larger diameter transition track?
Finally, I had to quit using a Bachman Annie on my Aristo stainless 4 years ago as I am convinced that some sort of electrolysis occurred between the cast drivers on the Annie and the stainless track: required serious cleanup every 10 minutes of operation to the point of serious frustration. (I had no problem with the turned steel drivers of my LGB locos.) Of course, that was just on DC, not DCC which I am presently using. 3) Does the K-27 have power pickup thorough the drivers or throuch a 'shoe' a la LGB? 4) Are the drivers of the K-27 cast rather than turned? 5) Has anyone with stainless track experienced unusual black deposit on stainless while using the K-27?
6) Any recommendations of DCC decoders for ease of installation on the K-27?
I can perhaps answer all your questions. I currently have 3 K27 models on my layout. I have both stainless and brass track, run both DC and battery power, and have numerous LGB 1600 turnouts (which are gradually getting replaced on the main line)
I should note that I did provide some thoughts to Bachmann prior and post release and and this locomotive is clearly my favorite locomotive on my railroad.
The very early first production locomotives had loose counterweights. While there are likely a few of these models still in the market with this issue, Bachmann replaced all the ones that Dealers notified them on. If you get one of these Bachmann will supply free replacements which can easily be replaced.
The power pickups are through the drivers and work exceptionally well in both DC and DCC. With one K-27 I have installed Hybrid Drive so that I do not have to clean wheels or track. My others have other boards at present and work fine but these do have to have their wheels cleaned from time to time like any locomotive. As an aside installing Hybrid drive on your Annie will completely solve the issue you were having with the wheels.
The K27 has the expanded Aristo Craft socket which is identical to the one Aristo has been using for about 10 years. You asked about DCC use. QSI and ESU have DCC sound boards that plug into the socket. The ESU board supports all the functions including sound with no modifications. The QSI board requires a simple inversion transistor should you wish to use the on board chuff circuits rather then the boards auto chuff feature. There is one chuff sensor in each cylinder triggered at the half way point.
Perhaps it would be useful if I also commented on some of the comments that Matthew provided.
There is an issue with the horizontal play in the axles on the locomotive. On mine, Dave Goodson was good enough to lock the first and fourth axles with washers. This solves the problem of the locomotive sliding sideways on curves and striking objects near the track because the whole locomotive tended to travel to the outside of the curve, but still allows the inner axles to slide, which helps the locomotive on tighter curves. Other people have come up with other solutions, or run theirs as-is, in some cases adjusting the clearance along their lines to accomodate the 'slide."
As shipped the drivers of the K27 locomotive can go around 5 ft curves.(the total locomotive an tender need a little more then a 6 foot diameter). This is accomplished by a design with has an inner and outer axle with side play. Many of us have layouts designed for smaller locomotives and the K27 is rather large by comparison. Because of the locomotives size and design the side to side play can cause clearance problems on many layouts. As noted Dave Goodson developed a method to reduce the side to side play by locking the 1st and 4th axles. I did this on one of my K27s. Because of the subsequent tendency to derail I quickly altered the approach. One can accommodate 90% of what Dave was trying to accommodate and improve the locomotive tracking at the same time by locking the 2nd and forth axles. Locking the axles will indeed reduce side to side play but will increase the radius required. With this mode the locomotive will still easily handle LGB 1600 curves This after market improvement is totally optional. I should note that over time I have adjusted my layout to accommodate a greater side to side play and have not decided if I will do this mode to my other K27s.
Note that if you have the snowplow version you will have to do a minor mod for Aristo manual turnouts to prevent the plow from hitting the manual throw mechanism.
There is an electrical issue whereby the chuff trigger requires power for the light source in the optical chuff ... this makes the chuff inoperative at low speeds without modification. The chuff was also designed on a positive trigger instead of a ground trigger, which posed some problems with some existing control and sound systems. Those users who chose to use "auto chuff" of one kind or another avoided the issue entirely, and others installed circuits to power the light source, and invert the chuff signal. On mine, Dave Goodson installed a new chuff timer of the magnetic reed type on the rearmost drive axle, which works very well, and again circumvents the entire problem.
Perhaps I can correct this observation a little. Low track voltages not low speed. Most sound boards designed for DC use require a battery to run at low track voltages. The K27s motor will start at a slightly lower voltage then the chuff circuit. A pair of diodes on one motor lead (the LGB approach to allow the electronics to activate before the motor) or coupling the locomotives and battery circuit both solve this issue. DCC or RC users will not see this issue. The second issue raised is the need for a chuff inversion for many but not all sound systems. The ESU plug in board for DCC users works fine and the RCS plug in board for RC users has the required inversion built in. If you want to use a sound system that requires the inversion it is very simple to add.
There are some questions as to the current handling capabilities of the on-board electronics. My locomotive is equipped with battery power and radio control, and most of the factory wiring (the ubiquitous "Super Socket") have been removed .... so I'm not in a position to comment personally on the extent of the problem. You might ask Bob Grosh, or other users who installed DCC equipment about their results with this.
I try to follow all reported problems for this locomotive and I am not aware of any current handling issue if the stock electronics are used.. I run my railroad at 21.5 volts DCC and have many hours on my K27s
Finally the motor and gearing produce some interesting problems. The locomotive has a large motor and very solid metal gears, which is good ... but the gearing of those gears is such that the locomotive behaves as if it were a truck stuck in third or fourth gear sometimes, and has some issues with acceleration (see: very steep (fast) curve) and a lot of power consumption in the higher ranges. That said, the locomotive will pull prototypically long trains nicely, and with a little practice on the throttle can be made to run well, however if you have grades on your layout, you will find it difficult to find a "cruise" speed and walk away from the controls, particularly with a long train. To date there is NO fix for this particular issue, but I understand that the speed control inherent to some DCC systems may deal with it somewhat.
An issue you will likely never encounter. The K27 has a top speed that is very similar to other plastic models built by companies such as Aristocraft, LGB, Charles RO and others. This top speed is twice a K27 prototype speed and much faster then many comparable brass models. While the prototype modeler likes the slower speeds, the market still demands the faster speeds. Most of us use the after market electronics we have chosen to adjust our top speed to suit our preferences.
The K27 has a very large motor and some electronics in the market have problems powering the motor/gear mechanism. Comments such as a sluggishness, poor acceleration or stuck in third gear are an observation of a poor marrage between the drive and the electronics. Other electronics in the market is designed for high efficiency drives and the power is smooth across the speed range. I have used Lenz, QSI and ESU drives in my K27s. All have high frequency back emf as part of their design and none have any of the problems reported by Matthew. In fact several sound manufacturers had to slightly alter their software to accommodate the ultra slow performance that is achievable by this model.
Hope that helps.
Stan Ames
http://www.tttrains.com/largescale
