I promised y'all I'd share when I started building these trucks, so, here we go....
Well, after scouring the internet and about 40 issues of Model Railroader Magazine looking for good refs, I started the power trucks for the Railtank Project. Here's what I'm building.
Using an N-Scale GP 20, I took 1/160 measurements and roughed out a plan on paper using a 1/35 ruler. Then, using .125 X .250 and .125 X .080 strip stock, I roughed out the general shape of the main steel components of the truck.
I cut apart the modern freight truck I'm using for the wheels and journals and using the cut-off journals, glued the truck frames to accept them.
Once I had the right general shape, I took the two sides and taped them together and started cutting and shaping by chucking a Dremel drum sander into my drill press and raising the table up.
So, here we have the final shape of the two sides and the journal/races dryfitted in. I still need to make final measurements to make sure the axles are the right distance from the top of the truck frame.
More tomorrow, any comments, or, praytell, criticisms welcome.
Cuhail 8)
Cuhail 8)
