1 - 20 of 52 Posts
Ray Dunakin
Discussion starter · #1 ·
I just completed a new structure for my In-ko-pah Railroad. It's a replica of an old miner's cabin in the little town of Ione, NV. Here's a photo of the prototype:
As you can see, there are some unique features that really give this cabin a lot of character, particularly the homemade metal awnings over the windows, the stovepipe with its fancy clay cap, and the window cut into the original door. One of the awnings appears to be made from part of the roof of an early automobile.
I only had a couple of photos, taken from a distance, and the the cabin is surround by tall weeds and junk. So I had to "fill in the blanks" using my knowledge of other cabins similar to this one. I also added a window to the blank wall on the opposite side.
The model is made of styrene, textured and painted to look like old, weathered wood. The awnings and corrugated roofing are made of brass. The door and door frame are modified Grandt Line castings.
Here are some photos of the model:
I replaced the saw mounted on the front of the cabin, with a bighorn sheep skull. The skull was sculpted from polyclay...
The rear of the prototype cabin was not visible. On my model, I opted to give it a different style of siding -- a common practice on many of these old buildings. I also painted it with grayer, more muted colors, to represent the shaded side of the cabin...
Here are some close up detail photos. The window shades were made from Tyvek, cut from an envelope and painted a yellowish tan. The curtains were made from lace, saturated with acrylic matte medium and then painted grungy off-white::
Here's the cabin temporarily in place on the layout. I still need to do more work on the site, to bring the concrete "soil" up around the cabin. I also need to add plants, an outhouse, and other details:
The cabin is located in an area without wiring, so I installed an LED powered by two D cell batteries. Here's a test shot of the cabin at night:
As I complete the cabin's site on the layout, I'll post new pics:
http://www.raydunakin.com/Site/IRR_Miners_Cabin.html
Enjoy!
Discussion starter · #10 ·
Yes, this is the first building in what will become the second town on the layout, the town of Grandt Cliff. I don't have a lot of room there so there will only be a couple cabins, a depot, and maybe 2 or 3 stores/commercial buildings.
Town #3 will be a bit more substantial, with several commercial buildings and a couple small houses, a depot, a mill, and some interesting mining structures. I haven't settled on a name yet but I'm leaning towards "Mineral Ridge".
Ray, simply gorgeous! I'm glad that someone else works in styrene, which the late Al Armitage said was the prefect medium. Your aging methods are tops, as is your attention to detail. Of course you've raised the bar even higher, which means I'll have to tread water harder to even approach the level of your work. Wonderful.
Discussion starter · #15 ·
Thanks!
Joe, when I started modeling outdoors, I remembered Al's articles in the Gazette and other mags, promoting the use of stryrene. I was skeptical that it could be a good substitute for wood, but his models always looked pretty good even in a much smaller scale. Now, after having used it for a while, I'm a big fan of styrene! It's a breeze to work with.
Ray, I was wondering, how did you paint your walls to make them look like aged wood? Did you prime them first, then apply various colors of paint? Did you rub off some of the paint?
Me, I sometimes apply various shades of acrylic right over the thoroughly washed white styrene, since the paint seems to streak in a "looks like wood grain" manner. At other times, I first spray everything with gray automotive primer out of a rattle can, and apply the color afterwards. I don't keep track of the process very well, so I am constantly relearning the proper technique.
Anyway, how did you do it?
Discussion starter · #18 ·
I first apply a light coat of white primer from a spray can. This gives it more "tooth" for the acrylics to grab on to. Then I apply the acrylics (Apple Barrel flat craft paints), using thinned washes. I start with light colors, streaking a little on here and there, and gradually build up layers, letting each layer dry before adding the next.
That's my paint technique in a nutshell. I'm writing up a magazine article with much more detail covering both the texturing and the painting.
1 - 20 of 52 Posts
