I don't know much about DCC but since I assumed that DCC was a standard I thought that all DCC voltages would be the same. After looking at several manufacturers web sites it seems that the hardest thing to find is a decoder maximum voltage specification.
Decoders seem to be rated according to gauge and amps but not according to voltage (unless gauge IS a voltage standard). If it is a standard, I have not been able to find out what that standard is. I did find a booster that had a 3 way switch for HO/O/G.
Perhaps rather than a DCC variation in voltages the difference may be in the analog DC maximum voltage a decoder can handle but if so I have been unable to find any such ratings. Even in G Scale it is not uncommon to find variances from 18 to 24 volts from one manufacturer to another.
I have three questions:
1, is a decoder limited to a "standard" voltage for a specific gauge?
2. Can a HO decoder be used on a G DCC layout? I'm not concerned about amps - just voltage.
3. If each gauge has a DCC voltage standard, what are those voltages?
I am probably taking the following out of context but I found this and it seems to suggest that the track DCC voltage is 16 volts without reference to any gauge:
"To achieve good sound results SoundTraxx designed their voltage of 16 volts DCC as the recommended maximum DC track voltage for their decoders.
Lenz GmbH has designed their systems for the past 10 years to have a factory default DCC track voltage of approximately 16 volts DCC. We choose this DCC track voltage because we desire to deliver a minimum of 12 volts DC to the motor per NMRA S-9 in both standard DCC mode and in the address 0 mode which is designed to operate non decoder locomotives"
Today I bought a Digitrax DH123D but now I don't know if my LGB MTS 1/2/3 power will burn it up or not.
Am I likely to discover Success or Smoke if I hook it up?
Jerry
Jerry
