1 - 9 of 9 Posts
Had some time to kill yesterday before an appointment out near Pomona yesterday so I went into a store on Pomonas antique row, this particular shop always has one booth full of model train stuff tho mostly HO and O junk, but there were two large scale items to my surprise, a Kalamazoo engine and tender and a Kalamazoo passenger car, I wasnt going to buy them until I saw that there was a 50% off flyer posted in the booth, in fact almost all the booths were 30-50% off, thats the economy these days. SO I got the loco, damaged as you can see for $25, and the passenger car for $15, not too bad but the loco needs work and I kinda doubt HLW still has parts for 20 years old Kalamazoo stuff.
So, THIS IS A PLEE FOR PARTS, look thru your parts boxs...
I needz...
Sand Dome
Stack cinder barrier
Headlight housing
Boiler Backhead
Most importantly...
Pilot wheel assembly and swingarm
Now if I cannot get the parts to restore this engine, then I will try to rebuild it with whatever I can assemble myself, but I'd like to try to get it close back to original condition as possible, then I can add additional detail parts and consider repainting it.
Thanks in advance for any help that can be provided
PS YES it does run
Vic, Your timing sucks. I used to have all of these parts and literally threw some of them away. Sorry. What I do have is the backhead, sand dome and swing arm.
I think the pilot truck is the same that Hartland still uses. I may have original plastic wheels somewhere (no promises on that one). I'll check.
Definitely talk to Phil about this and what you're doing. I know Hartland used to dump a lot of the old Kalamzoo stuff in their grab bags.
You may want to replace the gears on the axles, or at least pin them.
Chris
· Super Moderator
Hmm, the photos didn't come up when I looked earlier for some strange reason. I had forgotten how toyish those original locos were. Hartland definitely improved on them! Not sure if Phil will have the old domes, but the new ones definitely look better. If you're going to repaint it anyway, you may as well get the good stuff.
Later,
K
Do these look like they'd help, Vic?
Sorry about stack top. I literally had a pile of them and threw them in the recycling.
Chris
PS. I've never seen a Kalamazoo loco with a large headlight, i.e., that reflector you've got looks too big. I've had a number of these locos and the headlights were all quite small.
Chris thats great! PM on the way
Thats 80% of the parts list right there. I've got the metal wheels, left over from the CP Huntington project. I'll try to get in touch with Phil about the gears, so far sounds like they are fine, but would be a good idea if I upgraded them to new.
1 - 9 of 9 Posts
