After planning and then building the layout area and track base...I am finally attempting making the track. Decided to build the staight sections first and seeing how it goes, and then later when I get my track bender I will do the curves. All are being built in six foot lengths which will be moved outside like sectional track and put in place.( I hope !
I have put together a jig for the straight lengths that seems to do the trick for me, so far so good.
http://s4.photobucket.com/albums/y113/reelroader/?action=view¤t=DSCF2617.jpg
The ties I am using are Red Cedar fencing that is ripped into 7/16 X 7/16 inch strips, then cut on a chop saw to 3 1/2 inch lengths. After I have enough cut , I soak them in used diesel oil for several days...looks much like creosoted ties after that. From what I have been told the diesel oil bath protects the ties for a long time, we'll see. After soaking they are left to dry for as long as it takes...usually three or four days...I do this outside, so drying time depends on the weather conditions. The spikes I use are 1/2 inch black steel..using the black steel so they will rust into the ties and hold well, lesson learned from others I have talked to. For this effort I am using the ties without stips under them to hold them in place...which means four spikes per tie. I figure doing it this way will make it easier in the future to remove a tie for replacing, if the need comes for that, which I am sure it will.
The track will be sitting on a concrete roadbed so it can't sag and will drain well. I am concerned about it lifting with ballast getting under the ties, so will fasten the ties with a clip of aluminum every four feet. The ties well still be able to slide side to side a little...in case of any movement in cold or hot weather, but not lift, or so I hope!
So far I have 42 feet finished and ready to be tried outside.....just need to get the curved sections done and the weather to improve a little more.
http://s4.photobucket.com/albums/y113/reelroader/?action=view¤t=DSCF2618.jpg
I have painted the rail , which is aluminum code 250 ( running battery RC ) but the rail I left out all winter to test is losing the brown paint... are there some spray paints that hold up better on the rail ? This was not Krylon..next test will be with it and hope it holds up better !
Anyway...this is a real learning experience so far...slow going...but enjoying myself. If it doesn't hold up as well as I figure it should, I may not be saying that in the future.
Garry NCGRR
Garry NCGRR
