1 - 9 of 9 Posts
Along with the following post, I have a styrafoam building which has had some details knocked off and broken. They can be glued back on and/or repaired, but what kind of glue to use. I did not originally build this and have no idea what type of glue to use. It is an outside building so weather is a factor. Anyone have any suggestions? Something that will not melt the styrafoam.
I just used Liquid nails construction adhesive to make some coal loads for my hopper cars. Worked fine on the blue styrafoam. I did paint it first tho with some latex paint.
For Styrofoam I usually recommend 3M Fastbond Contact Cement. It is water based so it does not attack and melt the Styrofoam. You brush it on and let it dry, takes longer than solvent based contact cements, and press the parts together. Most other glues that are air dry will stay liquid in the middle since no air can reach the glue through the Styrofoam.
You can read about the Contact Cement here: http://www.tapplastics.com/shop/product.php?pid=271&
Russ
Thanks Russ, but I'm afraid that is a little too rich for my pocket book and I sure don't need a quart of it. I have just a few repairs to make. I do appreciate your response though.
1 - 9 of 9 Posts
