hi all, my first post.
i recenlty purchased an Aristocraft Class 66 in EWS, i want to use it using a battery but am having a little trouble. the manual is quite basic and doesnt say what battery to use or how to hook it up,
i purchased a 12v battery from an electrical store and as there was no instructions on how to install it i had to figure it out myself, there are two plugs, one plug goes to one end of the loco and the other plug to the opposite end. i placed one plug onto the +ve terminal and the other plug onto the -ve , the lights came on but then the wires started melting/smoking
Im not electrically minded but thought that the wire was melting because too high voltage was running through it
so i then tried a 9v battery, the lights came on but the motor wouldnt run
as i say i have never even looked at a g scale loco before so would basically like some advice on how to hook up a battery to the loco
im assuming all aristocraft locos are similar so hopefully someone can help.
