I've just spoken with the fourth person who has contacted me through my website that has not been using quick blow fuses inline in the positive wire between the transformer and the track. (I assume the battery folks are doing this too but...)
I wanted to get a post on this on the new forum to say, if you aren't using one STOP WHAT YOU ARE DOING RIGHT NOW AND GO GET ONE! ***DO NOT RELY ON YOUR CIRCUIT BREAKER ON THE TRANSFORMER!*** Ideally you should be running a fuse that is closest to the peak amps you are pulling. For initial power up tests on a new engine converted to DCS or one I've been working on I always use a 1 amp fuse to ensure that if there is a short somewhere I will pump 1amp max through it and be much less likely to damage the electronics.
Also, I use two fuse holders to allow me to switch out (put in higher or lower fuses) on the fly. So if I have a 5amp fuse in and need to go to a 10, I put the 10amp in the second fuse holder then pull the 5amp out.
Raymond
Raymond
