What seems like years of fussing and cussing, I have my Legend to where it's a pleasure to run. At the beginning I rotated the poker part of the burner 180 degrees and made a fuel tank since I didn't have one. Of the many other mods were to make the suspension solid for better valve timing, install a Ruby oiler with restrictor cap, bore the cylinders to 9/16", remove the superheater and run a steam line through the boiler, and leave the cross head guides loose. The best thing I did was to install a fuel heating system at Diamond Head. I installed a Dave Bailey globe valve where the top of the sight glass use to be. I did have to re-tap the valve from 3/16 to 5X.05m since there's no room for the adapter.
To solve the difficulty in lighting the beast, I installed a smoke box door from a scrapped S12.
