1 - 10 of 10 Posts
I am working on a scratchbuilding project in styrene, and have some small (0.02 thickness or less) gaps to fill. I have some "MMD Fast drying white putty" that I picked up at the local hobby shop, but it is really thick and pasty. It works okay, but for filling tiny gaps it really is too much. It easily overfills the gap, resulting in lots of sanding and sometimes some damage to the project.
Any suggestions for what I should use? The material I am scratchbuilding in is styrene.
Thanks.
You can also thin your putty. Squeeze some out onto a piece of glass or metal, add MEK, acetone, or some other liquid solvent, and stir. You may have to experiment a little to find the right solvent, but I've found that MEK is the most effective and least expensive option. Generally, whatever you're using to bond the styrene should work.
Well, I had been using styrene scraps to push it in. The problem was more that the stuff was too thick. I will try thinning it with MEK (I have some on hand) and see how it works. Thanks.
First off, how large of a gap are we talking about here? I can see using plastic pieces to fill large gaps, but for small ones and small holes, there is nothing better than the Squadron Green putty that Dwight mentioned. It carves, files and sands perfectly after drying. If you get some shrinkage after it is dried, just refill. Nothing is going to work 100% the first time, every time. You have to keep after it until you get what you want.
I've never had any luck with Squadron putty as I find its too thick and dries to fast, but I never tried to thin it out before, so I'll add that to the list.
So I've been using Testors Model Master Red Putty which has worked out really well.
-Ray
1 - 10 of 10 Posts
