Engine gets starts slow then speeds up
9176 Views 38 Replies 18 Participants Last post by  Madstang
I'm trying to figure out why my engine seems to take a while to warm up. When I first bring it out, it runs very slowly and then after several runs, it eventually seems to go faster.
I just recently installed my track. It is 75' and a mix of lgb and aristo brass. I've been cleaning the track with a pole sander and making sure the pickups are clean and shiny. I've tested the voltage on the entire system and it is consistent.
I do have a 2-3% grade in some spots and the engine is so slow when it starts that it just can't make it up these hills. Once it has "perked" up it has no problem with these grades.
Jim
21 - 39 of 39 Posts
Yeah, thought about that, he said he cleaned the sliders, so sort of assumed that any lack of spring tension would have been reported, but we need a definite "checked that" on this one I will completely agree.
Like Nick said, a good commutator cleaning will fix this 99% of the time..
Seen, and fixed this problem numerous times over the years, mostly caused
by over-zealous oiling in most cases I think...
Paul R...
Posted By W3NZL on 06/11/2008 4:46 AM
Paul R...
I have had this problem in smaller scales and learned to not oil things very much and only do it when necessary. I have a feeling this is the problem.
Art
Ok, thanks for all the help.
I found that if I spray wd40 at the wheels, it gets up to speed quickly. This makes me think I've got some sort of gunk or corrosion or bent something. While it has no trouble with a small 20' gondola (LGB Toy Train), it still can't manage to haul my new 40' gondola around the track.
I also found some joints that hadn't been screwed together (aristo brass). That and cleaning also seems to help.
Well, could be the power pickups are not working well at first... I'd pull the loco apart and check the path of electricity from rails to motor. Clean the wheels, and you should not need wd 40. Maybe your track is dirty, and fix the track.
The things you are saying now do not really match what you originally posted, i.e. bad rail joints.
Let us know what you find helps, then we can help the next guy faster!
You know, all of my locomotives start out a tiny bit slow, even when I run them inside, and then little by little, they speed up, and I turn the power back some to bring their speed down. They're all LGB; even my starter set Stainz does this, and now it's 24 years old, and it always did it. The Porters and the little industrial steamers do it, too. Happens both outside and indoors. You know, on my railroads, I kinda think it's normal...
SandyR
OK....just though of something....try a different power supply....if they ALL act the same way maybe it is the power pack you are routinely using.
By trying a different power supply maybe we can narrow the problem down....to it being a faulty power supply.
The give away is that they all act the same way....that is not the norm or possible, as problems with a locomotive are always associated with that one loco and NOT the whole stable of locos!
For giggles and grins get a differnt power supply with the same rating as the one you are routinely using....making sure that it works properly for the person you are brorrowing it from....THEN get one that has, at least double or tripple the power of the one you routinely use.
But try ALL the locos on both power supplies!
This will tell you 2 things, by process of elimination....
1. If in fact you ARE having an issue with your power supply in question.
2. It will isolate if you ARE having a problem with any of your locos....or having an issue at
all with the locos.
Remember that this process is only going to be succesful if you have already eliminated the track problems....dirty track, and conductivity....the sliders will tell tale when you run all of the locos...you could also remove the sliders for testing AFTER you have tested as suggested above.
I can't wait to hear the results.
Hope this helps
Bubba
The slow acceleration sounds like that of a transistor throttle which is designed to provide slow starts and stops. Unless I'm missing something here, (wouldn't be the first time hehe!). What kind of power supply are you using? Does the engine also stop slowly?
Depending on the age of this locomotive depends whether or not my comment is valid.
BUT - LGB had an electronic 'delayed acceleration' or 'soft-start' system integrated into some of their earlier locomotives.
I don't know enuff about LGB to give the correct title to this feature, but maybe an expert can name it.
Maybe THIS is the 'problem'...it's not a problem, but is there intentionally.
On the other paw, 'starter set' locos tend to have had a hard life, with over-oiling being just one of the hazards they experience at the hands of newbies who may be keen to 'improve' the performance of their loco.
tac
From his first post,
"I'm trying to figure out why my engine seems to take a while to warm up. When I first bring it out, it runs very slowly and then after several runs, it eventually seems to go faster."
Possible something on the engine that frees it self up after it warms up....
Another of his posts,
"Something that I did not mention before was that this problem occurred indoors as well. When I would first start running the train on the starter circle, it would go really slowly and then perk up. This perk up would happen after half a pass around the starter set, so I ignored it. Is there something I should be doing to 'oil' my engine? Does the smoke fluid clean the inside of the engine?"
Possible thick or dry grease made worse with the addition carpet fibers, cat hair, floor stuff, etc., it's surprising what small piece of hair or thread can do wrapped around an axle(s)..?
His last post,
"I found that if I spray wd40 at the wheels, it gets up to speed quickly. This makes me think I've got some sort of gunk or corrosion or bent something. While it has no trouble with a small 20' gondola (LGB Toy Train), it still can't manage to haul my new 40' gondola around the track."
Probably, the WD40 helps the above problems, but doesn't fix it, thats why it it doesn't pull like it used too....
Bubba, I've used several different power packs, the best of the lot being a PH Hobbies PS-3, and I noticed the slow start, later speed-up phenomenon with all of them. For me, the locos seem to run at a reasonable speed right from the git-go, but after a few laps they begin to speed up. I prefer a moderate pace for my trains; don't like to see them racing around, it's not prototypical. So I throttle back until they are back to the slower speed that I like.
But your point is certainly valid, and that's a really good way to check on one's power pack! And yes, since ALL of my engines exhibit the same phenomenon, it would have to be the power pack. Unless...as the train runs, its sliders (or pick-up skates, if you prefer) actually act as track cleaners, so there is more current available to the locomotive???
SandyR
I have learned that too much lubrication in the axle bushings of locos that have bushing pickups (like my U-boats) will cause a lot of problems - slow action, lurching etc. Once flushed, the loco is fine again until the bushings get dirty again. One place to use the conductive lubes...
Ok, I think I have some helpful results.
1. I just received a new aristocraft Eggliner and when I set it loose it runs fine. Fast, steady on the up grades, and has no trouble pushing a little gondola.
2. When I tried to run both trains on the track at the same time, things just did not work right. The trains went very slowly and would simply stop for periods before moving forward a little again. As soon as I took off the LGB 2-4-0 starter engine, the eggliner did great again.
So, this would seem to eliminate a few possible problems because they would have had the same effect on the eggliner, right?
- it can't be joint continuity
- it can't be brass track cleanliness (i didn't even clean it tonight)
- it can't be the grades
- it doesn't seem to be voltage drop due to my long power cord
In fact, it would seem to point straight at the lgb engine itself. The other night I did some tests on that engine. I turned the engine upside down and using small jumper wires, applied power to the pickups and it sped up quickly and whirred away nicely. Then I took the engine out to the trackside connections and applied power to the engine there. Again, slightly slower, but still fine. In both cases, it went slowly at first, but then sped up after a few seconds. That may be normal lgb behavior.
Given all this above, I have three possible culprits:
- for some reason when on the track, the pickups/wheels are not conducting properly.
- there's something wrong with the innards of the engine that is preventing it from operating under any weight
- something is wrong with the electronics that is causing a significant voltage drop.
Thanks for all the help! I realize this is going on for much too long, but I'm hoping it will help someone else someday...
For reference, here's my layout stats:
75' of brass track, mix of aristo and lgb
5-10' radius curves
2-4% grades
using aristo train engineer (not basic) using linear mode
20v 1A lgb starter set controller
Jim, you cannot expect that transformer to run both locos... In fact, you really should get another one, 1 amp is marginal on one loco...
Try a larger capacity transformer, and then report back...
Funny, none of us guessed this....
The Aristocraft train engineer even in linear mode has pulsed power internally and this is why the eggliner runs OK but the 2-4-0 does not as the 2-4-0 needs more current than the eggliner at low speeds due to the 5 volt internal regulator circuit for the smoke and lights.
You need a good DC power source for the Train engineer, I suggest at least 3 amps at 20 volts for running the 2-4-0. Look at the Aristo Elite which can meet present and future needs.
I run one of the LGB 0-4-0 engines under the Christmas tree, and have for several years with Bachmman's cheap little power pack, runs fine, pulls several cars, will start slipping it's wheels before it stalls....
The older 0-4-0 LGB engines without smoke and electronics will run great on the small Bachmann power pack. The newer 2-4-0 that comes with a tender, smoke, 5 volt lights needs more power than that supply can create, plus some of these have sound units.
Hooray! My problem is finally solved. It was indeed a power supply inadequacy. I'm happy to say I'm sitting outside on a beautiful summer night, drinking wine, and watching my little black engine pull all four cars up and down the grades with no problems.
I upgraded my starter set LGB power supply (20V 1A) to the MRC Power "G" (22V 10A). I chose the MRC instead of the Aristo Elite (recommended above) because I could get it locally and had read online that it worked well with the Crest Train Engineer and specifically LGB trains.
Thanks for all the help. Sorry for not understanding electronics.
Jim
Posted By jimtronic on 07/13/2008 8:07 PM
Jim
I think I stated this solution on June 26th....better late then never.
Bubba
21 - 39 of 39 Posts
