1 - 20 of 21 Posts
When Dan introduced his latest building, I knew I now had a reason for having a roster full of USAT 4 bay hoppers. I also knew I had my hands full when the freight line’s Dispatcher called and asked if a tractor-trailer could negotiate my street.
The elevator is big and heavy, all sheet steel welded construction, with an e-coat finish. The elevator was palletized for shipment and is built with the silos as a separate piece, which does limit the weight of each section to a manageable amount.
After painting, I added plexiglass to all of the windows. Reaching the uppermost windows required the gluing of a handle to the plexiglass pieces, which could then be positioned using a “grabber”. I used “liquid-tape” to simulate rubber roof coating on the flat roofs and corrugated aluminum soda cans on the shed over the silos. I still haven’t decided what roof covering I should use for the sloped roofs other than being painted. I also added a light strip inside the main structure, using magnets to support the strip. After having continual maintenance on my resin buildings re-gluing and reinforcing warped sections every spring, it’s nice to have a structure that will require minimal annual maintenance.
"When Dan introduced his latest building"
Latest is right; there isn't a word about it on their web site. How big is that bad boy?
wwo looks great, like the color.
Nice elevator Jim. What is the height and diameter of the round silos. I would like to build one this summer.
Is it powdercoated on the inside also? With the open windows I would expect moisture could get inside. If you close it up, then condensation inside has no place to escape, did you make a vent?
Just curious, because anything that can eventually rust worries me just a tiny bit.
Discussion Starter #16
Leon, the silos are 6" in diameter and 24" tall. Check price with Dan, he was offering a discount to MLS members.
Greg, the e-coat process coats all surfaces and the bottom of the elevator is open to allow for drainage.
Greg try not to worry.
It will be a long time for that metal rust through.
Even my Garden Metal Model bridges are still in great shape and I wish they would rust for photos.
Discussion Starter #18
Finally got someone to buy the naming rights, lol. Got a local sign shop to do the logo on magnetic material, works great on a steel structure.
Marty,
Dissolve some steel wool in white vinegar. Let it stew for a few days and paint the solution on your bridges. Instant rust.
Best,
TJ
1 - 20 of 21 Posts
