1 - 20 of 30 Posts
Pete Thornton
Discussion starter · #1 · (Edited)
This little beast turned up today, from Peter K's estate. It's essentially a flywheel car that makes a live steam loco work harder to accelerate or slow down, thus simulating the interia of a real train.
Those look like solid steel flywheels and the ends of the 'box' are solid cast iron. The thing weighs a ton - intentionally to make sure the wheels grip and it doesn't just get dragged. One flywheel was disconnected (the gear was moved on the shaft so it didn't get driven.) That may be a way of making it work with only 1/2 the inertia!
I have no idea who made it but it is a nice job. I will be taking it to Jerry's SC&M to see if (a) his track can handle the weight and (b) whether it works. I have a little english train of Thomas stuff with a 'Countess' to pull it. If it works, I'll have to find a Thomas box van to hide the internals.
I had something like this about 1/2 way done inside of a Bachmann two axle car when other projects took priority. I got to thinking that I would like a way to increase the drag as the speed increased. With the flywheels, once they are up to speed, they don't apply much resistance to keep them spinning.
I was thinking about some type of fan that pushes against air or possibly fluid (like a torque converter in a car). Or possibly a generator that spins against a bank of resistors like a dynamic braking scenario, like Dave Hottman's load testing setup.
Will I ever get back to that project? Guess I better finish my heavy Mikado, for some reason the timing is kicking my a$$. Timed light Mikados, S2, Challenger, FEF, Hudson, K4, among others....... Why is this one being a little b(it hard)?
Discussion starter · #4 ·
In prior discussions I have heard that a fan is the way to go if you want to limit the speed. Something to do with aerodynamics and non-linear resistance?
This inertia simulator isn't designed to control top speed. If you reduce throttle once the train is moving, it will help the train continue to roll, as if it were big and heavy.
I have one of those inertia cars as well. The guts were made by Ernie Noa. One change I made was the belt.
I cut the width to about a third of what yours is. This reduced the power needed to get and keep it rolling.
Bob Paule, Kevin O'Conner and Larry Bangham made 3 inertia cars before Erinie. They were more complex with higher speed gear driven flywheels with ball bearings everywhere. Kevin used to pull his with his Aster Big Boy.
It was calculated to simulate a 50 box car load.
Bill Payne also made a few inertia cars using music box gears. Bill has one for his Aster Lion.
Ernie used to pull his inertia car with several different engines. He got some great stack talk (bark) from his Aster SNCF 140-C-302.
Must be my age - was in my late teens in the early 1960s. When I see the word "Drag," my mind jumps to the old "hot car" songs of that day, and I start humming "Burn up that quarter mile!" Inertia doesn't do it, but Drag does!
Sorry, David Meashey
Looking at the designs, it seems revolutions on the wheels have to be geared up quite considerably. What kind of ratios are we talking about?
I just realized my small Märklin 0-6-0 BR89 (T3) maybe would benefit, as it is very difficult to maintain a slow and EVEN speed. Also, running into sharp curves, makes things even worse.
The locomotive has a 3-axle coal tender, that is empty, so there would be ample space for a spinning axle inside, with flywheels.
I have to confess, I can't seem to think clearly about the physics. It would be much simpler to add two flywheel axles, than adding a geartrain for one flywheel axle.
Basically, on top of each wheel axle, would be an inside flywheel axle. But having one single gear(belt), would not give the ratios I see in the pictures. One could perhaps add a second belt, using the two axles for a "second stage" as well, only friction might become a bit of a problem, due to the extra sprockets revolving at another speed than the axles.
Where do you get your gears / sprockets? (I can't seem to get the forum search to work for me.
A good number of years ago at Diamondhead larry Herget or Larry Bangham, I do no remember which, had a drag car. It was set up to provide not only an inertial response, ie, a large flywheel but also drag from a separate fan.
If I remember correctly the car was a boxcar that was also weighted, weighed about 10 pounds, and had a chain drive to a clockworks gear box that had flywheels on one end and the fan on the other. The inertia of the flywheels on startup and coasting was great and the fan provided a variable load with speed.
This was back in the early 2000s and there may have been a write up on it in SITG.
Discussion starter · #16 ·
Thanks for letting me know who made mine.
I've been hanging on to this photo for inspiration for many years. I found it in 2001. It's from David Bailey in the UK. Fans, flywheels and weights.
Pauli, my drag car has perhaps a 10:1 ratio driving the flywheels. I think anything 1:10 to 1:20 would work.
One solution is to find a small toy with a flywheel drive in it. The GScalecentral guys just noted a Lego block that has a flywheel drive.
https://www.gscalecentral.net/threads/momentum-wagon-candidate.315310/#post-603486
I've been waiting for something to turn up that was the right size and shape. Not sure if the Lego is it - and note there are 2 versions.
ServoCity was a wide variety of sprockets and gears. The robotic guys use them.
Discussion starter · #17 ·
A quick google produced the zeCar which seems to be a scientific teaching aid. It's just about the right size. It's even available from Walmart and Amazon.
Ruger, by all means! You could use the dynamo to slow down but also to accelerate the car if required (with dynamo used as an electric motor). In fact you could program the whole thing using a microprocessor to sense the behaviour of the live steamer precisely and to intereact with it to optimise the motion and inflict the required behaviour. That would be a brilliant project for anyone high-tech & computer minded. It would not have the disadvantage of mechanical gear noise and of course you could equip it with any synchronised (digital) sound system you wished, bells and whistless and all... A potentially sweet contraption;-) which could literarly breathe a new quality of a yet unseen level of realism into live steamers. Best wishes from Indoors, Zubi
PS to some degree (without steam sounds and whistle;-) this idea has already been used on electric bicycles in Japan. Although majority of the recent models do not have electric breaking (some still do) but they all have computer controlled assisted power drive (power assist). Contrary to some electric bicycles in other countries, electric bikes in Japan sense the pedaling force, the speed and all the requred parameters to achiieve optimum comfort of cycling (at preset level of strenght - you can choose the level of support/assistance). There is also a maximum speed depending on the kind of a bicycle (child, sports, etc, and I think that there is also a legal limit, above this limit power assistance does not work but you can cycle faster using your muscles). These bicycles are absolutely fantastic to ride and they get better and better every year. They are a common sight in Japan these days. Panasonic is the market leader. Best wishes from Indoors, wishing to go for a ride;-(... Zubi
1 - 20 of 30 Posts
