Posted By HMeinhold on 02/11/2008 1:43 PM
We made some for our donkeys. However, they are not metered. See here:
http://wegmuller.org/logging/Sheet16.pdf
Posted By Eric M. on 03/20/2008 6:33 PM
The cool thing about these is that the position of the drain handle is fully adjustable so we can make sure that it is accessible amongst the network of pipes on the donkey engine.
Henner and Eric....thank you for the drawing & picture of your lubricator.
I'm especially interested in the drain valve design shown on your Sheet #16. I'm can't determine how it works. I can see that the sleeve(#162) threads onto the bottom of the Body(#160) and that the Drain valve(#163) threads into the sleeve. I can see where there are 1mm x 1mm notches at right angles across the top of the valve, But, since the 2mm hole through the bottom of the Body appears to continue right on through the valve, what stops the oil/water from coming out the bottom? I assume that rotating the handle on the Sleeve opens/closes the valve, but I don't see how that action restricts the flow of oil/water out ther bottom.
I know it's me, but what am I missing. I really want to try this design because of its simplicity and as Eric stated in his message, "the fully adjustable position of the handle".
Thanks in advance for any help you can provide.
