I have gone through the list looking for some good information related to implementing reversing loops but I haven't found what I need. Most of what I have found seems to be focused on LGB system, controls, and their accessories. While I do have a LGB trolley, the bulk of the rail system will probably be powered by MTH locomotives and ultimately their DCS system. The track is Aristo-Craft SS and most likely the switches will be too.
In the process of designing my layout I am trying to decide whether or not to include a reversing loop in the system. I like the idea of being able to turn the a train around and have it go the other direction but I am concerned about the mess this is going to make out of the controls. Regardless, I may want to run trains in the opposite direction.
It appears that using DCS, the polarity of the track voltage and the polarity of the control signals must be matched to the direction the train is facing. I assume that all I need to put a double pole double throw (DPDT) switch into the system to deal with trains running in different directions, regardless of whether I do it will a loop or manually pick the locomotive up and turn it around. Correct?
Can the track controllers, particularly the MTH ones, assist in automating this activity? Is there a way, using sensors, to tell the track controllers to do this automatically? Is there a controller that would adapt to this environment from another manufacturer? (I know I can do this pretty easily with an independant controller, such as a Basic Stamp or other micro controller but ... at least for now, I would rather not go that route)
