I read some good stuff on in the 3 inch 8 ohm speaker thread.
I used the configuration with a rechargeable 8.4 volt battery
that gets charged from track power. The problem is that during
installion and experimenting using the idle sound wnd no track power,
I wore the battery down to about 6 volts and then the idle sound is intermittent
as well as the running sound from track power. My question..is this configuration
worthwhile?
I took a speaker out of a pc speaker. Clamped some wires on it to see how it sounded, well I got the motor boat sound as it turned out to be a 4 ohm.
I did not keep it hooked up long. Could this have done some damage to the sound card?
I hooked back up the 8 ohm speaker and put on a new non rechargeable 9 volt and the idle sound seems ok as well as the running sound with track power. I did not leave the track power on long so i would not charge the nonchargeable.
Any thoughts?
worthwhile?
Any thoughts?
