Hi,
I am working on a model of the first D&RG caboose – the small four wheel version, which is a bit longer than my DSP&PRR one – though eventually that will change as there is a longer version of the DSP waycar in the list to be done sometime.
This one is built on a sprung chassis, that as it was one of the last made I had to lengthen; the rest of the model follows the basic system I devised for the waycar article that is still in the ‘Articles’ section of MLS .
A short précis of that is the body is 1/8” or 3mm plywood sheathed in planked styrene card; the roof is a couple of layers of .030 styrene card (easier to bend than one layer of .060) with a minor variation that a space is left in the top layer for the cupola to be seated in.
The chassis/floor is plastic 3mm thick PVC solid foam with bits of other thicknesses where required the steps are aluminium sheet strips, and were very high! These were later replaced with an open pair of steps, and later the design as on the waycar. All the detail is made from plastic.
The main interior is empty and painted black; the cupola with its ‘all round ‘ windows is painted with light green sides and a light blue inside roof with a black painted area where it is to be fitted. I have added some sunshades for the side sliding windows; on top is the housing for a lantern.
Here are some photos of the model so far –
The underside of the chassis /floor - the brass wire between the axleguards will be covered with some white (styrene) plastruct U channel. The outer ends of the springs sit in some pieces of aluminium strip bent to shape. The same strip is used for the steps.
The body being built, showing the planked cladding; the roof supports are set at the location of the cupola.
The body with its associated bits roughly put together, and in (red oxide) undercoat.
An interior view of the body construction. The canopy ends have been planked to give some extra stiffness to the area - the roof here is .080 thick.
The inside of the cupola, showing the slides for the side windows, and the exterior sunshades on them. The inset for the end windows can also be seen - the light green is not light enough and will be changed!
A final view of it 'all together'. A lot of painting is still needed and just for a change I have the decals already in stock!
Now a question - I live in the UK, so I do not have access to caboose red color - can anyone describe it please? We have a bright red color, which I think should be dropped down a\ bit by adding some maroon into it - was it that sort of color? I would describe my version as a slightly dulled red, but not tuscan or red oxide (that has brown in it), tuscan having more maroon: in fact it could be called a maroon by itself!
