Posted By johnnyboy on 02/09/2008 11:33 AM
Pete,
The reinforced mortar comes from Jack Verducci 'How to Design and Build your Garden Railroad'. I hope I cite this right and don't get in trouble but pg 40 states
"Drive the rebar into the ground in the same way you would install a grade stake. Next, form a piece of rebar to the the track curvature. Wire the rebar together, forming a spine under the track. Next, mix a batch of mortar and spread it over the rebar to form a roadbed. When the mortar has cured,the rebar will lock the roadbed together."
Aha - Jack lives in sunny California, if I'm not mistaken. Hence he can get away with driving rebar into the ground. /DesktopModules/NTForums/themes/mls/emoticons/blush.gif
In my area, where we get solid frost for 3 months and hot sun for 3 months, (in between it varies randomly,) there would be a problem with frost heaves and expansion/contraction.
I let my track 'float' on top of the roadbed. As I didn't need track power, I used ordinary n/s rail joiners between lengths of rail, and I never had a joint problem or misalignment due to heat or cold.
