Cheap bottle but the hose looks a bit complicated, small, and expensive??? Is that an airbrush fitting and hose? Do ya have to screw it on the Goodall type valve every tine you want to add water? I'm sure it will work fine but....
I bought a $0.99 spray bottle at the store and removed the spray gutz. Bored out the knozzel adjuster gizmo. Turned a part to fit the knozzel adjuster gizmo and hold a plastic hoze. Assembled it. Made a Goodall type valve with a hole that just fits da hoze. Da hoze shoved into the hole and the water pressure expands da hoze to make a seel with the valve. Pretty simple and cheap.
Jack
Jack
