Here's something I discovered almost by accident!
I picked up a K-Line GP diesel dirt cheap, got it home, and found out ALL 4 axle gears were cracked, binding, and stripped.
I was going to write it off (I only paid $20.00 for it!), but then decided to take it apart.
I found all the plastic axle gear shafts were cracked. I decided to try to fix them.
After a couple of failed ideas, here's what I came up with...
I measured the diameter of the wheel axles, and then used a drill bit that was just slightly (.005) larger. I reamed out the plastic gear, while holding the crack closed with a pair of pliers.
Sorry for the lack of pictures, taking the picture was an afterthought....
You basically want the metal axle shafts to easily slide in with no friction (the tension is what cracks the gears), but not be so loose as to wobble in the gear.
Then I used a couple of drops of CA (epoxy would work too), and slid the axles back in - before you CA the second axle back in, make sure you have a piece of track handy to check gauge BEFORE the CA dries (slow CA gel would be a great idea here).
The loco works great now!
