1 - 3 of 3 Posts
If you look on the 16 Millimeter Association website http://16mm.org.uk/ under Model of the Month, Tony Bird did a couple in 16mm, with oscilating cylinders called "Cracker."
This is, of course, the inspiration for the Cricker locomotives, both Berkley and Westminister. http://www.sidestreetbannerworks.com/locos/loco72.BLW.html
And some where there is a geared locomotive page. http://www.gearedsteam.com/byers/byers.htm
Yes, build more Byers, one cylinder or two! Heck, three or four, if you can figure where to put them.
Regards, Mike
It is a pity all the follow ups of the Cricket are not based on these drawings. When the original was designed, only the small ad existed. BTW, I helped Susan out with one of the links on her page.
Regards
1 - 3 of 3 Posts
