Posted By Greg Elmassian on 11 Feb 2011 09:26 PM
Can I ask the amp rating on the bridge rectifier you destroyed?
I was not aware RS had 20 amp bridges.
to trip the house breaker, you needed to be pulling over 15 amps ac... that is roughly 150 amps at the dc side, since you say the output is about 1/10 of the input. (so the amps are 10 times more)...
That would have been a nice short.
In any case, a dimmer switch that can handle 15 amps is going to be interesting, I would not do this... also on the DC side you would need something with an amp rating ten times as high.
Resistors better be large and calculated for the power output...
I think the key is picking the right transformer in the first place...
Greg,
The bridge was a 20 amp bridge. I was kind of suprized myself that RS had one (in stock no less). After speaking with my brother in law (an EE) he suggested that I use a dimmer switch on the AC side, and then proceeded to ask me if I wanted one. I replyed sure, so we go out into his garage and he gives me an industrial grade 1500 watt dimmer switch. So I think that should work. But speaking of transformers in retrospect I would should have gotten one with a lower voltage output, but lesson learned.
Craig
