1 - 20 of 31 Posts
If you are reading this post, you are like me in loving traditional DC Track Power operation, but want the ability to control your trains remotely without having to mortgage your home, or spend time converting all of your locomotives (I have over 30) to DCC or Battery. I have built an inexpensive DC Track Controller that you can build without having an Electronics Degree. All of the parts I used were ordered from Amazon.
Start with ordering an inexpensive Computer Power Supply that is 24 volts and at least 10 amps. They have larger amperage PSU's available if you plan on running multiple trains or motive power consists. Single Motor locomotives like Steam Engines typically draw .5 to 2 amps. Add lights and smoke generators and you could be up to 3 amps per locomotive. Dual motor locomotives like USA Trains and Aristocraft Diesels will require a minimum of 3 to 4 amps per locomotive. At 10 amps I can run two steam locomotives and one USA trains NW2 dual motor with lights and smoke enabled without issue with a 10 amp PSU.
Click here for the PSU I use
Next, you will want to order the wireless Speed Controller. I have tried multiple brands, but found that this one works the best, and has the POTs for starting power or manual operation. It does not come with the 12 volt battery (Model A23) for the remote. You can pick them up at any Battery Supply store. I got mine at Walgreens or CVS Pharmacy. The remote can go as far as 100 feet from the control board. I can even go around the side of my house which is Stucco where I have a siding (rail yard) without issue.
Click here for Speed Controller
If you want manual operation as well, you will have to order a 3 way switch. If the switch is thrown in forward direction or reverse, the wireless receiver will not work. I can give you the wiring diagram if you wish to add a manual switch to your controller.
Last, you will want an enclosure of some kind. You could also mount the equipment to a board. I chose an outdoor enclosure as mine is permanently mounted to the exterior wall of the house. I added a 24 volt fan blowing out to allow cooling of the electronic components while in operation. I also added a 2 way switch rated for 110 volts as a power on/off switch.
Click here for the enclosure I used.
Additional materials needed:
-A power cord that has the ground plug (important if you will leave the equipment outside.)
-Screws to hold the equipment down
-Wire (I used 16 gauge that I stripped from an old orange extension cord.) This is used to wire the jumpers between the power supply and the speed controller. You will also want at least 16 gauge wire going from the speed controller to the track. I use 12 gauge direct burial wire connected to multiple points of my mainline approximately every 10 feet. Track joiners like Split Jaw work very well in preventing conductivity loss.
60833
60834
60835
60836
60837
60838
I also added a Low Pass Filter to convert from PWM to linear power. This is not required, and most locomotives will run more smooth in slow speeds with PWM. I replaced all my directional lights with LED's, and noticed that the lights that should not be on flicker with PWM power. If you would like a low pass filter added, I ordered the Crest Low Pass Filter. I can send the link if you would like that as well.
Feel free to reply if you are interested in this easy-to-build wireless controller. I will answer any questions you have. I have been running this setup for over a year now without issues, and have only replaced the 12 volt battery in the remote once.
Enjoy!
Next, you will want to order the wireless Speed Controller. I have tried multiple brands, but found that this one works the best, and has the POTs for starting power or manual operation. It does not come with the 12 volt 23 amp battery for the remote. You can pick them up at any Battery Supply store. I got mine at Walgreens or CVS Pharmacy. The remote can go as far as 100 feet from the control board. I can even go around the side of my house which is Stucco where I have a siding (rail yard) without issue.
-Wire (I used 16 gauge that I stripped from an old orange extension cord.) This is used to wire the jumpers between the power supply and the speed controller. You will also want at least 16 gauge wire going from the speed controller to the track. I use 12 gauge direct burial wire connected to multiple points of my mainline approximately every 10 feet. Track joiners like Spit Jaw work very well in preventing conductivity loss.
View attachment 60833 View attachment 60834 View attachment 60835 View attachment 60836 View attachment 60837 View attachment 60838
Enjoy!
Looks really great. Which low pass filter did you use?
This is a very cool option you have come up with. I love this type of project. Lot's of cool electronic widgets like that on Amazon that are direct from China. Voltage regulator boards, remote control boards etc. I use stuff like that at work and in the hobby. Well done.
Discussion Starter · #13 · (Edited)
Uhh, so you realize how large a 23 amp 12v battery is? About the size of a loaf of sourdough bread.
It is a 12 volt battery, TYPE A23, as in battery model number. typically used in compact garage door opener remotes.
Yes you are right. I made the assumption of 23 Amp with the 23A marking on the battery. I also corrected this in the original post.
Discussion Starter · #14 ·
Thanks Jason. It was a fun project to build and execute.
So I got this up and running works great fun to do. Thanks so much for the idea and instructions.
Question though, I want to run two separate loops using two separate setups. The problem seems to be that the remotes send commands to both boxes, they must be on the same frequency. Any ideas on how to overcome that? I have a question in to the manufacturer.
Discussion Starter · #16 · (Edited)
Unfortunately there isn't a frequency pot to change the channel. You can find out if the company can ship out a speed controller on a seperate channel. The only option would be to run one of the loops manually using the supplied POT and adding a three way switch to the wire harness. This will disable the remote when the switch is thrown in forward or reverse. Then use the POT as a throttle to adjust speed. Of course that then defeats the purpose of wireless control. Hopefully the manufacturer has the option of a seperate channel on the frequency they use.
Good news I contacted the seller on amazon and ther appears to be a fix. You solder a corresponding joint in both the receiver and transmitter and it changes the channel to not interfere. I’ll try it today. Pic below.
Font Parallel Plan Diagram Terrestrial plant
Discussion Starter · #20 ·
That is awesome news! I am glad they had a way for you to change the channel. If I ever decide to add another loop or separate spur with another wireless controller I will know what to do.
Thanks for the info.
1 - 20 of 31 Posts
