David
You will need to be a bit clearer in your request though in truth few commercial signals are available. i believe that a few manufacturers have made searchlight signals though you did not state your scale.
First off, are you looking for just a model of signal? and then a semaphore or a searchlight? Finally a single head or double headed signal.
Or are you looking also for the logic that goes with it to drive the signal aspect? This is far more difficult for two reasons. First the electronics must be weatherproof for use outside and more importantly, signal logic is very complex. The real railroads used several different types of signal logic (all the way from ABS to CTC) and these all required different logic sets.
As you can see, building a model of a signal system can be a fairly complex undertaking depending on how close to accurate you wish to be.
The current issue of the Modellers Annual has an article on a building a very nice F scale (1:20.3 scale) semaphore.
Regards ... Doug
Regards ... Doug
