I have (2) USA GP38s. The 1st loco has a Sierra Soundtraxx system installed in the fuel tank with the supplied speaker from Sierra. (A 2-1/2” round speaker made by Kobitone, 8 ohms, 0.5 watts numbered 49211). I wanted to trainline the sound into the 2nd loco when they run together. As a test… I connected a Phoenix speaker (A 2-1/2” round speaker, 8 ohms, ?? Watts, number SP-2.5SQ: 824-660) in parallel to the Sierra speaker. Well… the sound was coming out of both speakers for about 30 seconds when a puff of smoke came off the Sierra board followed by a bright glowing component. Needless to say … the board was cooked.
After reading about ohms on the Internet (should have done this first)… I discovered that hooking up two 8 ohm speaker in parallel changes the ohms to 4. I’m assuming the Sierra couldn’t handle this and blew.
Has anyone ever hooked up two speakers in one locomotive or trainlined the sound to a 2nd unit?
To add to the challenge… I noticed there is a place to mount a 2” speaker under the rear fan in the top of the locomotive. Is there a way to wire the sound board to run a speaker in the fuel tank and a speaker under the rear fan in the first locomotive so that the locomotive can run solo… but be capable to run a third speaker in the 2nd unit when both locomotive are operated together?
Can a Sierra card handle the power needed or would a Dallee 11 watt amplifier be needed?
I’m not very knowledgeable about this stuff (if I was, I wouldn’t have cooked the board ).
Any help or thoughts would be greatly appreciated!
Thanks, Russ
Thanks, Russ
