I have come into possession of about 50 8x11" sheets of heavy cardboard. Think twice the thickness of cardstock. I want to cut it into strips about 3/16" or 1/4" wide to build some stock/cattle cars.
I have a small paper-cutter but can't seem to hold the cardstock firmly enough to get a straight cut. For example, as I start to bring the knife down, the stock seems to twist/slide towards the bottom of the sheet. Hope that makes sense.
Anyway, saw a different style of cutter in the hobby store that uses a circular blade that you run across the stock. Has anyone used one of those and if so, how well do they work? Any suggestions as to how to cut these strips?
Oh, yes, I know I will have to seal the stock with shellac or lacquer or such to stiffen it and prepare for painting.
Thanks in advance.
Wildbill
Thanks in advance.
Wildbill
