1 - 4 of 4 Posts
Today I have installed battery R/C into another K-27. This time a little differently.
My customer has mounted two speakers inside the loco body. One under the smoke stack facing UP. The smoke unit has been removed. The other speaker is in the firebox facing down. Pix to follow.
This meant I did not need to mount a speaker in the tender.
First up was to remove the weights.
I made it easy again by cutting off the excess screw thread with a cutting wheel.
http://www.rcs-rc.com/pics/Bachmann-K27/00_Remove_weights_s.jpg
Then I broke off all the speaker mounts with a pair of pliers and a knife blade.
http://www.rcs-rc.com/pics/Bachmann-K27v2/01_Remove_speaker_mount_s.jpg
Once all the plastic had been removed I smoothed off the floor with sandpaper.
http://www.rcs-rc.com/pics/Bachmann-K27v2/02_Smooth_floor_s.jpg
This allowed the battery packs to sit flush on the tender floor where I glued them into position with Silicone roof and gutter sealant.
http://www.rcs-rc.com/pics/Bachmann-K27v2/04_Batteries_glued_in_s.jpg
Next I fitted the RCS # Y-CABLE which puts the two 7.2 volt SubC 2400 mah NiCd battery packs in series to get 14.4 volts.
Then I mounted the PnP-3 on the Bachmann socket pcb and the rest of the Phoenix sound components on the rear of the tender floor.
http://www.rcs-rc.com/pics/Bachmann-K27v2/05_Components_mounted_s.jpg
I am trying a different way of mounting the antenna in this model. Don Sweet has achieved good range by simply coiling the antenna up in the coal load. I glued the antenna around the rim of the coal load with a tag on the end to connect it to the matching tag on the tender body shell. See pic # 12.
http://www.rcs-rc.com/pics/Bachmann-K27v2/06_Antenna_in_coal_load_s.jpg
Next I mounted a two way cable on the front of the tender truck to carry the speaker output through to the loco. This connects with a matching connector on the loco.
Bachmann have very neatly made this possible by mounting the connection pcb securely in place. It was very easy to remove the screws on the tender steps etc and place the cable beneath the pcb and the tender floor.
http://www.rcs-rc.com/pics/Bachmann-K27v2/07_Speaker_cable_s.jpg
The RCS RX-8 receiver was glued in position just in front of the rear support stanchion. The antenna was fed through a small hole I drilled in the body, shortened and mounted on the outside where the rest is connected by a screw.
The charge jack and Phoenix programming jack were both mounted under the water filler hatch.
http://www.rcs-rc.com/pics/Bachmann-K27v2/08_Components_in_shell_s.jpg
The two wire plug was inserted into the PnP-3 as shown and the Orange chuff wire fed down to the rear for connecting with the Phoenix P5 sound. I removed the White smoke unit wire as it was no needed.
http://www.rcs-rc.com/pics/Bachmann-K27v2/09_Install_PnP_3_s.jpg
The rest of the battery power supply and sound system wiring was connected up. This is mostly simply a plug in operation. There are a number of screw terminal connections. The chuff wire and speaker connections required soldering.
http://www.rcs-rc.com/pics/Bachmann-K27v2/10_Sound_wiring_completed_s.jpg
The remaining connections from the top of the tender shell were added next.
http://www.rcs-rc.com/pics/Bachmann-K27v2/11_Loco_wiring_completed_s.jpg
The RX-8 cable was plugged into the PnP-3 and she was all buttoned up and ready to go.
The antenna connection can be seen upper middle in the pic.
http://www.rcs-rc.com/pics/Bachmann-K27v2/12_Shell_on_tender_s.jpg
Sound system and performance testing will take place on Tuesday when the owner collects his pride and joy.
If the speakers in the loco idea is successful I will try and write it up.
I had the same problem with two posts with multiple pictures. When I clicked the submit button I got the busy icon and it just hung. I had to close my browser to escape.
The second time I just walked away for a couple of hours. When I came back it was still hung and I closed my browser again. Oddly enough the post was there the next day.
I'm not the powers that be, but I have been told to open another window to add a reply. I haven’t tried that yet.
There's a bunch of work-arounds for this 'bug' posted elsewhere - mostly suggesting (1) add reply in stages [add/insert text+a pic/submit/repeat and (2) compose your message in Wordpad or MS Word before copying it to the post.
I am a two fingered typist and a lousy speller, so I compose my messages in Word (my E-mail editor). I include the URLs for any pictures or links and used the icons to insert them. But the forum still hangs when I try to submit a reply with pictures. I have no problem on other forums or our club web site doing the same thing.
In the thread “10mm White LED”, I replied by pasting in a small text message and added a couple of GIFs from the forum editor. It hung!
http://www.mylargescale.com/Community/Forums/tabid/56/forumid/35/postid/19250/view/topic/Default.aspx
After a minute or so, I hit the stop button on my browser, then the cancel button on the forum editor. After a couple of seconds it posted the reply anyway? Perhaps this is a work around!
1 - 4 of 4 Posts
