1 - 8 of 8 Posts
I finally have something to show off. Always wanted a garden railroad, will have one in maybe two years. Meanwhile I purchased this C-19.
I know, I know, the livery isn't all black. But I'm going to be staring at it while it sits on the shelf for awhile, and the silver and yellow show up a lot better in indoor lighting. I'll repaint it, maybe, when I have a railroad to run it on.
Anyone have Kadee coupler advice? I was planning on getting the G scale coupler with the standard coupler box. Maybe I should just order some and get a feel for their size, I'm not sure how I'm going to be mounting it in the front.
Another question. Which I guess I could test out myself, has anyone reduced the amount of ballast in the tender? Not the fake ballast, I mean the steel plates that are included for weight. I don't see myself using anything less then a 10' radius (20' diameter) curves, so less chance of string lining. I plan on going with radio control, as my other hobby is RC cars, so I don't need the weight for picking up track current.
I'll be experimenting I guess, as soon as my cars come in the mail along with some flextrack.
Oops, I've been mostly reading on this site. So no picture, for now.
Welcome to the party! I don't know much about the Bachmann C19 but I have a K27 that I love. If you have batteries etc. in the tender you don't need the ballast, in fact you may not even have room for it.
Thanks! Yes I wanted the K27 ever since they came out, but I was an Over The Road trucker for awhile and couldn't convince myself to buy one and have it sitting at home. Although now I wish I had, oh well. Maybe in a decade we'll get something new. Or maybe I will purchase a K36 from Accucraft.
Good point about the batteries, I was curious because the tender seemed so heavy when I pulled it out of the box. I'll weight it before any modifications to have an original weight to shoot for if I have tracking issues after removing the steel plates.
Now about the Kadee couplers. I'll wait until I get some rolling stock then purchase some. I bought one Accucraft gondola, and the rest are Bachmann cars. I know there is a drop in Kadee coupler for Bachmann cars, I am just used to the old style rectangular box, at least in the smaller (HO, O) scales.
I'm going to need a bigger shelf to display the 1:20.3 stuff on. I read about the length of the engine and rolling stock in Fn3, but actually having it in front of you is different. My shelf is 4' wide, so at least I have room for the C19 plus the caboose.
Super Moderator
Kadee makes a drop-in replacement for the Bachmann coupler.
https://kadee.com/htmbord/page916-1916.htm
Just unscrew the Bachmann coupler head from the draft gear, and screw the Kadee coupler in its place.
If you're using a Li-Ion pack (I use a 14.8v, 2600mAh pack in mine), they don't weigh much, so there's no reason to remove any of the weights. I just slide mine in through the coal load towards the back of the tender. Fits nicely. The Airwire plug-in board may prevent you from sliding it in, though. I've got an Aristo Revolution receiver in mine.
Have fun with your C-19. Mine is easily among my favorite locos.
Later,
K
Yes, my batteries are NiMH so are bigger. I am seriously thinking of changing to Li-Ion. I run mostly live steam so haven't spent a lot of time on batteries except for the RC.
I've received my Bachmann box cars and caboose, along with an Accucraft gondola.
From everything I've read and been told, the Kadee #916 is the best choice and drops in for all the Bachmann products. The Accucraft gondola gets the #901.
Also received the code 250 aluminum rail Accucraft track.
Thank you all for your help, or suggestions.
1 - 8 of 8 Posts
