I was trying to append to an earlier thread discussing this model, but can't find it.
I completed the build and, generally, it went well. Biggest problem was that the crosshead guides had not been finished and it took some patience to smooth and polish them. After that, everything was fine and it was an enjoyable build.
I tested the machine on rollers with both air and steam - it worked well.
Out on the track, things are a little more challenging and I'm finding it necessary to use the blower to maintain pressure even with light loads. My immediate thought was that the main blast nozzle was not properly aligned with the smoke stack but that doesn't seem to be the case. The one thing I do notice is that the hole in the blast nozzle is very small compared to anything I've seen before which makes me wonder whether it was finished correctly.
Before I go ahead and widen it, I was wondering if there was any guidance of how the blast nozzle should be configured.
BTW, here's a picture of the finished item against its big brother.
