1 - 7 of 7 Posts
Why does my C-16 run Jerky ?  And No , the answer is not because I'm standing near it  /DesktopModules/NTForums/themes/mls/emoticons/crazy.gif
Track is clean ,other engines run fine. Cleaned the wheels good, are the contacts inside the engine block ? How Do I get to them ?
Thanks, Bryan
I had a jerky running critter and when I added power pickups to the trailing car and wired it to the engine, no more jerking.
I have non-powered tenders and I added power pick to these and this improved my steam loco power pick up even on my LGB engines.
Plastic frogs and traction tires give problems and extra pickups spread out to the tender gives great improvement for track powered locos.
Your power pick-ups are rings screwed to the back side of the wheels which ride on the surface of the motor case. You may want to remove the wheels, one side at a time, to check those rings and the sides of the motorblock.
Jack
I checked the diagram Todd, but that did not help me much to understand the problem.
Thanks Dan, the tender has power pickups also. So I figured it must be in the engine.
Thanks for the tip Jack ! I will check that out.
1 - 7 of 7 Posts
