1 - 20 of 25 Posts
No, Mike, no caboose, sorry didn't even think about that. The weight was changed from the stock B'mann to one from a Dash 9 when we put the DCS system in it. You can barely here the whistle, but yes, it doese have sound. I discovered when I pulled the cars off the layout that the first coal car weighed about 5 or 10 pounds. I was told that Ray had glued pennies in it and uses it for a track cleaning car. ( It has cleaning pads on it )
Thanks for the compliment.
Cliff
WOW! 60 cars. I only usually haul between 5 and 8. /DesktopModules/NTForums/themes/mls/emoticons/shocked.gif I do have two grades however.
This does give me some confirmation that maybe I could run a dozen comfortably. Anything more would look out of place on my RR anyway.
Posted By flatracker on 06/27/2008 12:18 PM
Still curious, stock "annie" or did it have a BBT drive in it? Thanks.
BOb, yes , it is the stock drive train. The only modification to it was using a Dash 9 motor for the DCS system. ( because we needed to add a flywheel for the tac strip.) The gears on the driver axles and the worm gear are all stock Bachmann componets. It is the 5th edition drive train, the newest drive train from Bachmann, ( this a 2005 Sam's Club Christmas train).
Cliff
Discussion Starter · #16 ·
Posted By Mike Reilley on 06/28/2008 7:59 PM
Cliff...tell us more about your Dash9 motor change. I take it this an UP power mod.
Mike, we just removed the stock motor and took the worm gear off and put it on the -9 motor, Ray fabricated a flywheel for it ans installed it then added a rac strip. Then he put it in the Loco. Pretty simple. ( can't divulge to many secrets here ).
Chuck, yes, the TRAINS can smoke inside but us humans had to be relegated to great, hot, outdoors.
Cliff
Discussion Starter · #18 ·
Posted By neals645 on 07/03/2008 9:19 AM
Oh, I hate to be a curmudgeon, but there are only 55 coal cars in that train. Counted 'em twice. Still a very impressive run!
Neal
That's okay Neal, honestly, we didn't count them either. Never thught about it. But the fact that the FIRST coal car weighed more than ten of them together kinda makes up for it. It was full of pennies and used as a track cleaning car.
Cliff
Yeah, Neal's right. I didn't remember till I got home and counted them that I'm still short 5 cars for the set I used at the show. It was close enough and knew that even if it was 60 instead of 55 it wouldn't have mattered, it still would have pulled it so I didn't bother trying to post a correction on the post here. /DesktopModules/NTForums/themes/mls/emoticons/tongue.gif
Raymond
1 - 20 of 25 Posts
