1 - 3 of 3 Posts
I use AML clamps on AML (what a shock) and LGB code 332 without issue. I went into the shop and installed AML clamps on a couple of pieces of Aristo I had lying around and they held tight. No guarantees, but my simple test showed they worked on the bench!
I think the AML clamps are like all the others, just a straight “channel” for the clamping surface, they do not taper to fit the rail perfectly.
Discussion Starter #3
Thank you! I had hoped they would work. The Aristo 332 stainless track seems to be drying up? I wonder if they'll make more track and #6 switches soon?? I'm looking around for what brands will work. I just ordered some gargraves for storage tracks because it's so cheap. You just can't step on it!
1 - 3 of 3 Posts
