1 - 11 of 11 Posts
Good Day,
I am building my dream garden railroad in Pennsylvania. I am using code 250 flex track (brass) and was looking a switches. Now switches in brass code 250 seem pretty pricey and I thought maybe go with aluminum switches. Does anyone is PA or MD use aluminum switched outdoors on their layouts? I like switchcrafters prices not too bad. Just looking for some information from any modelers please help.
thanks again
If using battery power then aluminum is just fine. I actually have some nickle silver, brass and aluminum in use on my road. They all work fine. One suggestion for more pleasurable operation is to go with #6 or larger. I use #8's on the mainline, 6's on most industrial sidings.
I am designing my railroad now and I just got a couple of SwitchCrafter's aluminum switches.....wow that are VERY well constructed, excellent craftsmanship. They look like a work of art, almost too nice to lay down on the ground.
I'll be installing some EZ Air actuators on them and testing them in the next couple of weeks.
Aluminum switches will work just fine for you. The only thing is you may want to hit them with a coat of paint to knock the shine down, aluminum stands out pretty bad.
Does aluminum lose its shininess? I installed aluminum rails a few months ago and painted the sides but am hoping the tops of the rails won't stay so bright, as I'm modeling a little-used industrial line. I guess I could paint the tops of the rails a rust color?
I have a few switchcrafters Aluminum #6's and I love them. Very realistic, very smooth and so far have done well outside for about a year. I operate mine with Tenmile ground throws. If I had one complaint it would be the thorw bar--I wish it were about 1/2 longer on each side. The pilot and side frames of my USA GP-38-2 hit the ground throw--I had to make a throw rod out of wire to move the ground throw out further. Just nit picking here. I will buy more when I need more turnouts.
Matt
The aluminum does lose it's shine a little but not alot. Then when put with brass it appears really shiney.
1 - 11 of 11 Posts
