I have a USA SD70 that I did my first r/c, battery,and sound install on. The airwire install went so easily, I thought I would press my luck and add additional lighting functions with a TCS FL4.
I first disconnected the phoenix p5. Then I installed the FL4; connected ditch lights (green and purple wires), front headlight (pink wire), and rear light (brown wire). Lights are all LED's and they all have resistors. All CV's were changed to program ditch lights and rule 17 (dimming) for front and rear lights. Each function button on the airwire tx worked properly.
The problem is when the lights dim, they flicker.
When the ditch lights are on full intensity they are fine (steady). When I press Fn2 to make them alternate, as each one dims and then gets brighter they flicker.
When the headlights are on full intersity they are fine (steady). When I press Fn4 to dim them, they flicker at the dim setting. When I press Fn4 again they go back to full intensity and they are steady again.
The FL4 is grounded to one of the weights in the loco.
All testing has been done on the bench and the motors have not been turning.
Is it normal for the FL4 to flicker when brightness is anything but full intensity?
If not, any suggestions how to stop the flickering?
Ben
Ben
