Chooch,
The track is constructed of treated 4x4's spaced 8' apart and buried 2' in the ground. No frost heave here. Two 2x4's are screwed to each side of the top of each 4x4 to make a "T". In some places I had to bolt 2x4's to the side of the 4x4's to adjust the height. (See attached pics)Three 5/4 x 6" decking boards are screwed to the 2x4's between each 4x4. Exterior 5/8" plywood is cut and screwed to the decking boards. Finally the whole deck is covered with green roll roofing and cut to fit. I used brass Escutcheon pins (ACE Hardware) to attach the LLagas Creek code 250 track to the roll roofing.
The roll roofing has deteriorated somewhat in 10 years, but I filled the cracks with black roofing compound and it seems to work OK.
John, I do have a 1:32 caboose on order./DesktopModules/NTForums/themes/mls/emoticons/wow.gif
Hopefully I'll take some more pictures at the Bayou Steamers steamup May 26 and post them.
Pat
Timber and Tallow Branch RR
