Hello all!
TL;DR: The valve chest assembly tries to rotate side to side with each cylinder stroke.
I am new to the live steam community, but have been working around steam locomotives for the better part of five years. I just got an Accucraft Ruby as a Christmas gift and am having several problems with it. The locomotive was purchased as a RTR locomotive, so I was shocked at how poorly the QC was.
To preface, I am familiar with the steam up process. I have the Accucraft steam oil, 3-1 lube oil (used where appropriate), had proper amount of water, and correct fuel.
I will say that out of the box, things looks great. the first think I noted was the wheels were extremely hard to turn. I check multiple time to make sure I didn't miss something to keep them locked during shipping. Once I steamed up th locomotive, I was able to get it running and the wheel spun at warp speed just as most videos I have seen of the locomotive. However, after spending about an hour with the locomotive I could hear that something sounded off, which I assumed was the timing. It wasn't something I expected to get to that day, so I didn't worry much about it.
After the engine had been fired and got warm steam oil into the cylinders, I could move the locomotive with a bit of effort on a level surface. Thats when I noticed the running gear wanting to bind just past FDC on the fireman's side. It wasn't very tight, but tight enough that the wheels would stick for a second, then continue. I figured maybe this was something in the eccentrics to I set up my small air compressor to test the engine on air while I was going to time it.
This is where I noticed that while the engine was running, the entire valve assembly was trying to rotate under the smokebox. I am attaching a google drive link for your viewing pleasure. I have never seen anything like this. I knew some of the ruby's could be finicky out of the box with the possibility of timing being an issue, but this not not something I expected. I already send Accucraft an email along with the video in hopes I can exchange it for another one. My big questions are, has anyone ever seen something like this before? Is there something I could do to fix this? Do you have any tips on running a brand new ruby out of the box? (Things to expect, to look out for?)
drive.google.com
Thanks for reading!
Matt
IMG_4837.MOV
Thanks for reading!
Matt
