1 - 5 of 5 Posts
Hi all,
The rechargeable R/C batteries in my Accucraft Garratt seem to be nearing the end of their lives. I find that after an overnight charge they are good for one full run and after about half the second run, things get decidedly jerky. The R/C receiver and batteries are inside the water tank ahead of the smokebox - can anyone tell me how to get into it?
Martin
Hi Martin,
While I can't help you with the actual battery swap, I wonder how hot it gets inside that water tank... Most rechargeable batteries have a reduced life span as their operating temperature increases. Higher temperatures also increase the batteries' self discharge.
If you are using NiMH batteries, they generate a lot of heat while charging (temperatures up to 45C/113F are "normal"): good air circulation is recomended during charge to keep the temperature under control. Most properly designed battery packs and chargers will measure the temperature and stop charging if it gets too high.
My point is once you get the battery out of the engine, try charging it and see if helps.
Martin,
There are six screws that hold on the Garratt water tank , two on each side and two at the front, on some engine's the front two have been left off. On each side there is one cross head ( Philips ) screw and one hex head. They are accessed by turning the engine on it's side and using a screw driver /nut runner up behind the cross head guides. It helps to rotate the wheels by hand to move the crosshead out of the way.
Hope this helps.
Hi all,
Thanks to your information I was able to find my way into the Garret on Saturday. The problem was immediately clear, one of the four batteries was dead and refused to charge. I changed all four anyway (I don't want to have to go in there too often!), reassembled the water tank and steamed her. She ran very freely with no noticeable glitches at all so many thanks for your help.
All the best,
Martin.
1 - 5 of 5 Posts
